Timing at idle
Old Jul 4, 2008 | 02:28 PM
  #16
WS6T3RROR's Avatar
Talked to my old boss that runs the engine test lab at my last job today at a bbq. He said o2's are sensitive to too much exhaust pressure. They have a chamber that is fed constant oxygen from the atmosphere through the wiring harness. Too much backpressure like in a turbo app according to him will make the unit exagerate especially at rich/lean readings which the oem pcm keeps you constantly in only averaging around stoich. Said if you put them downstream of the turbo they should work fine for you again.
I know you're having good luck with the tuning open loop right now but i just thought i'd get that out there. Never hurts to pass on info.
Old Jul 4, 2008 | 02:37 PM
  #17
jchevy's Avatar
Thanks a lot for the info. I have plans to move them to the down pipe next time I have it out.
The open loop tuning has been going good, but this morning I was beating on the car a little bit and now I seem to be rich to the point the car will barely idle. Its rich all over though. I havent done any investigating yet, hopefully its something simple.
Fatdog2
Feb 13, 2015 08:19 PM
Gtpguy
Jan 26, 2015 04:50 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
jayblev95
Dec 1, 2014 06:55 AM
