Timing Covers, and Reluctor Ring Question
Old Sep 24, 2003 | 01:44 PM
95 Z/28 LT1's Avatar
Super Moderator
I am looking at replacing my engine from my 1995 with a 1996 engine and would like to know if I can use my 1995 timing cover on an engine with the reluctor ring on the crank (1996-1997).
I plan on keeping my OBD I.
Will the reluctor fit under the 1995 cover, or would I have to pull the reluctor ring off?
Also, would I be able to use the 1996 timing cover on my 1995 if I just plugged the hole for the crank position sensor?
Thanks in advance for any useful info you might provide.
Old Sep 24, 2003 | 03:01 PM
sssalah's Avatar
I think you can use the 95 cover with the reluctor, but you can also use the 96/97 cover with the sensor as a plug (assumin it availabel). You can also remove the reluctor altogether but then must use a pre-96 hub which is a tad longer to compensate for the reluctor thickness.
Old Sep 24, 2003 | 03:09 PM
Super Moderator
Thanks, that's good news. I'll just get a sensor to use as a plug.
I believe the engine I'll be getting will have a hub attached so I shouldn't have to change that.
Old Sep 25, 2003 | 02:37 PM
OBE1 95Z28's Avatar
No need to place a plug the sensor. It's an electrical connector so there's nothing to leak out. I have a 96 engine in my 95; used the stock 96 timing chain cover with the reluctor installed and an aftermarket keyed hub cut to the 96 hub dimension (shorter snout).
Old Sep 25, 2003 | 03:05 PM
Super Moderator
The timing cover that I will be getting won't have anything in the hole, so I at least need the sensor to plug the hole in the cover.
Old Sep 26, 2003 | 09:18 AM
OBE1 95Z28's Avatar
You're correct, the sensor needs to be installed in the timing chain cover (uses an o-ring). I misunderstood and thought you meant that you had to plug up the electrical connection in the sensor.
Old Sep 26, 2003 | 11:04 AM
You could probably use a freeze plug of the correct size. It would be whole lot cheaper than a sensor you're not even going to use.
Old Sep 26, 2003 | 11:20 AM
Super Moderator
I might give that a try if I can find one the right size.
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
heavenly_six
Dec 10, 2014 12:23 AM
