Timing Cover Seals
Old Oct 20, 2011 | 04:00 PM
  #16
camz28ryan's Avatar
Re: Timing Cover Seals
I would post a pic of the funnel but I don't know how. If you buy the blue funnel at oriellys, it's a flotool item 10701 cut off 1 & 3/4 inch off of the end it it will match perfectlly.
Old Oct 20, 2011 | 05:07 PM
  #17
ShowOff67's Avatar
so wait i gotta replace all three seals without taking timing cover off this sound weird.
Old Oct 20, 2011 | 05:20 PM
  #18
JGuy07's Avatar
You can do it either way, I just wanted to know which was best or easiest. I don't want to risk ripping the new seals. Only reason I can do it with my cover off is that I'm also replacing the cover gasket and oil pan gasket too. So it makes sense for me. But if you don't need to do the cover then don't since you might mess up the pan gasket you just did.
Old Oct 21, 2011 | 09:04 PM
  #19
ShowOff67's Avatar
anyone know where i can buy the three seals and the waterpump seal at?
Old Oct 21, 2011 | 09:17 PM
  #20
Procharged94Lt1's Avatar
I bought my fel-pro's at autozone.
Old Oct 21, 2011 | 10:12 PM
  #21
ShowOff67's Avatar
found crankshaft and timing seal cant find the little one for the waterpump
Old Oct 21, 2011 | 10:21 PM
  #22
ShowOff67's Avatar
can someone give me like a list of tools i need to do this. not the regular tools. like the tools i need to get the seals in and anyone know where i can find a low price hub puller dont wanna spend 60 bucks on one little tool im gonna use once.
Old Oct 21, 2011 | 11:38 PM
  #23
ascastil's Avatar
you should be able to rent the tool at an auto parts store. use a matching size socket to install the seals with a hammer.
Old Oct 22, 2011 | 12:14 AM
  #24
ShowOff67's Avatar
well the lower two seals are huge no way i have a socket that big lol but your talking for the waterpump seal and thanks for putting it in lamons terms
Old Oct 22, 2011 | 01:10 AM
  #25
JGuy07's Avatar
You can use something to lightly tap them in, place a piece of wood or something behind the cover to stabilize it if you took it off. If you left it on it's almost the same, just put the wood in front against the seal and tap the wood to push the seal in flush with the cover. As for the WP shaft seal, you can use a socket to help thread it into the hole without shredding it.
Old Oct 22, 2011 | 11:28 AM
  #26
camz28ryan's Avatar
Fel Pro part number from o'reillys is TCS 45956. You don't need special tools except what is mentioned in this thread dealing with water pump seal. You can rent a puller at O;reillys, the kit number is 67007.
Old Oct 23, 2011 | 01:04 PM
  #27
JGuy07's Avatar
If the puller doesn't come with a center bolt to push into the hub, you'll need a pretty tough grade 8 or else you'll bend it into an "s", frustrating.
Old Oct 23, 2011 | 08:42 PM
  #28
camz28ryan's Avatar
The puller kit number I gave you from O'rielly's has everything you need.
Old Jul 19, 2014 | 11:59 AM
  #29
Alialhussain's Avatar
hello everyone I have been trying to build the confidence in my selff to do this but i want to be ready and i would like to know what tools will i need exactly? i have not done this before so i am skeptical about it.
Old Nov 1, 2014 | 11:59 AM
  #30
here is a good one I started work on the car a couple days ago pulled all the stuff mentioned above off. but it seems that the car is leaking oil from the intake as well this is going to be a bigger job than expected I was thinking to pull the engine for this any ideas on how i can get this dude out the top because the car is on ramps and already apart before i found the other leak.
