Timing Cover Seals
Timing Cover Seals
I'm changing in the process of changing the Opti, and my car has always had a slight oil leak. Since I have easy access to the timing cover, im thinking of replacing the seals and gaskets for the timing cover.......Is this a pretty easy job?, I know I need a puller to get the crank hub off.....Is that basically the only issue to doing this?
And is this what I will need?http://shop.advanceautoparts.com/web...0_842106723___
oldschool
Feb 9, 2016 09:21 PM
