Timing Cover Seals
Old Jul 19, 2009 | 03:38 PM
deerslayinrenek's Avatar
Timing Cover Seals
I'm changing in the process of changing the Opti, and my car has always had a slight oil leak. Since I have easy access to the timing cover, im thinking of replacing the seals and gaskets for the timing cover.......Is this a pretty easy job?, I know I need a puller to get the crank hub off.....Is that basically the only issue to doing this?
Old Jul 19, 2009 | 04:15 PM
And is this what I will need?http://shop.advanceautoparts.com/web...0_842106723___
Old Jul 19, 2009 | 05:53 PM
Stl94LT1's Avatar
Yes, that's the Felpro kit you need, even has the water pump coupler O-rings.
Old Jul 19, 2009 | 06:45 PM
Well I need the waterpump gaskets anyways, so i guess i might as well just do it
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
