timing cover removel
Old Nov 24, 2009 | 08:38 PM
stenlt1's Avatar
tryin 2 check timing chaing cant get past the pulley got harmonic off cant get the last pulley how do i remove that
Old Nov 24, 2009 | 10:30 PM
SPEED#1's Avatar
You need to use a puller of some sort, a balancer puller works best!
Old Nov 24, 2009 | 10:42 PM
I doubt most people here are aware of the details of the Corvette LT1 accessory drive setup.
Old Nov 24, 2009 | 10:51 PM
charliediss's Avatar
Old Nov 25, 2009 | 02:08 PM
Stl94LT1's Avatar
Are you talking about the balancer's/dampner's hub? If so, I use a regular steering wheel puller to pull it off. Just make sure the center bolt is removed and the puller has something to push against.
Old Nov 25, 2009 | 02:36 PM
Stl94LT1's Avatar
This is not my greasy engine.
Old Nov 26, 2009 | 06:50 PM
JAKEJR's Avatar
Looks like you're trying to pull the hub.
In addition to the puller shown in the the photo, you need to insert a long bolt in the hole of the crank snout to give the center threaded rod of the puller something to press again. DON'T LET THE PULLER PUSH AGAINST THE CRANK OR THE CRANK THREADS CAN BE DAMAGED.
Choose a bolt or rod that is only slightly smaller in diameter than the ID of the crank snout and that's strong enough not to bend as the puller presses against it. Insert the bolt/rod in the crank snout and let the puller push against it.
You may have to find a way to keep the engine from turning over as you apply torque to the puller. I place a 3/8" extension in one of the flex-plate holes and have the other end of the extension wedge against the block, since I usually work on auto trans cars. If yours is a manual trans, you can try putting the trans in gear.
When I pulled the hub off my son's 96 Vette a few months ago, I first tried using an air operated impact; wouldn't break the hub's torque. So I used a 1/2" drive breaker bar with a long extension on it and a six point impact socket. If the hub hasn't been off before, it'll take quite a bit of force to break free the press fit. Once the fit breaks free, usually with a POP, the rest of the removal is easy.
You'll also need an installer to press it back in place. Some guys tap theirs on with a hammer, but I don't recommend doing it that way.
ALSO, BEFORE YOU BEGIN RE-INSTALLING THE HUB, POST HERE SO WE CAN TELL YOU HOW TO POSITION THE HUB.
Hope this helps.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Nov 26, 2009 | 06:57 PM
JAKEJR's Avatar
Although both my son and I have 96 Vettes, I've never tried pulling the hub with the engine in the car so I don't know about any clearance issue you may have with the rack or frame.
From what others have posted, some have had to jack the front of their engine for clearances, but to know for sure, you can post on the Corvette Forum forums.corvetteforum.com in the C4 section or the corvetteactioncenter.com and ask.
Jake
West Point ROCKS!! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Dec 3, 2009 | 08:10 PM
stenlt1's Avatar
installing timing cover
thanks for the pointer finally got the damn pully off was almost ready to call it quiets on this thing but know iam ready 2 but it back 2gether
Old Dec 4, 2009 | 10:53 AM
JAKEJR's Avatar
Unless you remember how it came off, it would be a good idea to track down Showbox's post on how to re-install it. It's on a site he created.
You'll need an installation tool for that (hoping you're not going the "hammer it on" route).
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 20 May 2010!!!
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
