Timing Cover Question
Old Jun 10, 2008 | 07:34 AM
TAEnvy's Avatar
Hey guys
Are all the timing covers from 93 through 97 the same?
I ask because I am installing a cloyes double roller in my Z28 (97) and I am deathly afraid of it rubbing cause I know the havoc aluminum can cause on bearings.
I installed it and put the cover on and turned it over as instructed and it left no marks, but I did some light clearancing all over for peace of mind. Then I heard matt lost his motor from the crank gear rubbing so I pulled it off again to double check.
In his pics I think our covers are different.
Here is his. Notice the red circles. On my cover those parts are recessed, not flat. I do belive thats were his rubbed.
Anybody with a 97 or maybe 96 with a cloyes that can comment on this. Where should I clearance?
Its not rubbing now but I dont know how close it is and I want to take heat expansion (no matter how miniscule it may be into account.
Old Jun 10, 2008 | 07:40 AM
There are 3 different covers used 93-97. Use some clay to mock it up and check the clearance.
Old Jun 10, 2008 | 07:43 PM
93/94 have the small hole for the Opti drive (just big enough for the splined shaft), 95 has a large hole for the Opti drive (larger diameter to clear the dowel pin drive), 96/97 has the large hole for the Opti drive, plus the hole for the CKP sensor.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
