Timing Cover Leak+Cost??
Old Aug 4, 2007 | 07:43 PM
s.reef's Avatar
My Timing cover needs a new gasket. How much do you think a shop would charge me to put a new gasket in? I work too many hours to do it myself thanks.
Old Aug 4, 2007 | 08:34 PM
raroz28's Avatar
it only takes a few hours to change it. Drain the coolant, pull the fan for more room, pull the crank pulley and hub, water pump is 5 bolts, timing cover is like 9. Cake job just kinda time consuming.
Shop is gonna cost a couple hundred I would guess.
Be sure to loosen all the bolts on the oil pan to drop it a little bit. You can re use the seal if you don't damage it.
Old Aug 4, 2007 | 08:41 PM
s.reef's Avatar
Ok thanks...hey you on mifbody.com?? See your from michigan
Old Aug 4, 2007 | 09:23 PM
raroz28's Avatar
nope, just on f-body.com and this board. Check the MI board here on cz28, there's a guy named IrocSS85. He'll do it for ya outta his garage. He's a little drive from here but the money you save in taking it somewhere is worth it. I've never had him do any work, but he's really knowledgeable, a GM tech, etc... Tons of people have him do work.
I would recommend doing it yourself. Take a few hours on a day you have spare time. The felpro kit is 8 bucks and comes with everything you need.
Old Aug 4, 2007 | 10:02 PM
s.reef's Avatar
where do you get the felpro kit?
Old Aug 4, 2007 | 10:27 PM
raroz28's Avatar
advance auto, murrays, autozone, etc... Comes with timing cover gasket, 3 timing cover seals you need, optispark seals, and both water pump gaskets. $7.98
Old Aug 5, 2007 | 12:53 AM
s.reef's Avatar
Ok thanks
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
