Timing cover install.....
Old May 3, 2004 | 03:07 AM
whatsup's Avatar
Guys I am in the process of getting everything back together after my new cam install. Everything was going well till I got to the timing chain cover. How does this go back on??? Do you have to completely drop entire pan?? I have removed the front four bolts on each side and cannot get it to move downward at all. Any shortcuts here. 93 Z M6...thanks
Old May 3, 2004 | 03:11 AM
Alex94TAGT's Avatar
I had to loosen ALL the bolts on the oil pan in order to get the front to drop down enough. Even then, it's tricky to install the cover without misaligning the bottom seal, or damaging the WP drive seal.
It's a pain -- patience is the key. Good luck...
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
