timing cover compatibility
Old Feb 19, 2004 | 11:56 PM
30thannZ28's Avatar
Question timing cover compatibility
Alright, I'm fed up with trying to find a 31mm freeze plug for the waterpump driveshaft seal area of the timing cover and I went to use stainless steel washers to plug it, but I got carried away with the dremel and accidentally grinded too much off the inside of the cover. I need to know if ANY other vehicle out there shares the same bolt pattern and same size crank and cam holes on the timing cover. I have the OBD I conversion and therefore don't need the CPS anymore and also have the CSI pump, so I don't need that hole anymore. Perhaps someone on this board will know if maybe and older chevy or such has a timing cover I could order to put on my LT1. I'm sick of the stupid issue! It's keeping me from fininshing the mods in my sig!! -frustrated....
Old Feb 19, 2004 | 11:58 PM
Why not just put an expanding rubber plug in it and be done with it? (one of those things that has rubber sandwiched by flat washers and a bolt through the middle)
Old Feb 20, 2004 | 12:02 AM
atljar's Avatar
You can use 95-97 LT1 cover from f-body.
You can use 95-96 imp SS cover too if you are going junkyarding.
Arent the LT1 covers really cheap though, 30 bucks or something new.
Old Feb 20, 2004 | 12:17 AM
InjectedSS's Avatar
Dude instead of getting a 31mm plug what I did was found a plug that fit in the SMALL hole itself.. I don't remember the size But dude just pull the cover or measure it with a dial caliper and go to your local autoparts store, tell them to bust out their clevite catalog, then someone in there is a section that lists all the freeze plug sizes clevite makes.. Just match one that fits your size and BOOM good to go.
The one that I found fit PERFECTLY inside that tiny round hole, but it wasn't like a press fit so what i did was just put copper sealant ALL OVER the FRONT & BACK of the seal, gooped that $hit on everywhere Then just let it cure.. NO MORE waterpump seal to deal with ever & no more leaks Been like that for about a year and a 1/2 now
Old Feb 20, 2004 | 12:23 AM
97WS6SCharged's Avatar
Epoxy works well, as does liquid steel or JB weld.
Old Feb 20, 2004 | 12:44 AM
InjectedSS's Avatar
Uhhh that's a big NO NO... Epoxy and JB weld DO NOT mix well with oils... Put that stuff in and say BYE BYE bearings
Old Feb 20, 2004 | 02:28 AM
I meant to patch up his timing cover, not to use inside the motor.
Old Feb 20, 2004 | 02:57 PM
InjectedSS's Avatar
WERD but if he usues it to patch up the inside of the timing cover then that is in the engine Either way, copper silicone works just fine, that $hit will harden plenty
Old Feb 20, 2004 | 09:47 PM
Ahh, just skip it.
Old Feb 20, 2004 | 11:47 PM
InjectedSS's Avatar
Ahh, just skip it.
HAHA werd
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
