Timing chain a tooth off?
Old Oct 27, 2010 | 08:46 AM
  #16
MeenZ28's Avatar
Well, I'm going to bite the bullet and get the timing cover off to see what I can see. I'll keep you posted. Might as well get the opti tested while I'm at it.
Old Oct 28, 2010 | 06:51 PM
  #17
Originally Posted by fstkmaro
I do not think a tooth off will cause the engine to run very bad. The ECM will try to compensate but will never get to where it should be. .
X3..... The irregularities caused by the incorrect cam/crank relationship are more than enough to throw the crank position sensor duty cycle out of range and cause the codes.
How can the ECM "compensate" for the cam being incorrectly phased to the crank? Maybe in a more modern engine with VVT..... but not in an LT1.
Old Oct 30, 2010 | 06:07 AM
  #18
Guest47904's Avatar
Guest
Don't think you have to go that far.....
If you put a cylinder at top dead. Once the cap is off, you merely check to see that the rotor is pointing in the direction where that cylinders contact inside the cap was. Cylinder 8 happens to be at about the 8 o'clock position. Cyl 4 is near the 9 o'clock position.
I recommend a back cylinder. Checks the state of the cam as well.
Old Oct 31, 2010 | 11:06 AM
  #19
MeenZ28's Avatar
Re: Timing chain a tooth off?
On one hand I love being right... on the other, I feel like a compleat dumbass for doing that in the first place. Once the timing cover was off it was obvious that it was a tooth off. put it right and put the rest of the car back together (even had the opti tested just for good messure - it came out fine, which didn't surpise me - it's brand new). and the car fires and runs like a champ. No check engine soon lights or anything. Thanks for all your help guys. I always come here first for technical questions.
BTW - Shoebox, half the things I've done I couldn't have done without your website's help, so a double thanks for you.
Old Oct 31, 2010 | 01:42 PM
  #20
Ya' gotta do stuff to learn...and you learn best by your mistakes. You won't make that one again. Glad you got it fixed up!
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
