Which Timing Chain Set?
Old Mar 10, 2004 | 11:55 AM
My Red 93Z-28's Avatar
Who makes a good timing chain set that is somewhat affordable?
Old Mar 10, 2004 | 12:14 PM
Will the stock timing chain hold up after 140,000 miles, i'm doing a rebuild and am wondering if i need to purchase a new one or not
Old Mar 10, 2004 | 12:39 PM
about how much is the oe replacement and the LT4 heavy duty timing chain?
Old Mar 10, 2004 | 01:20 PM
speedmiser's Avatar
On 92-94 lt1s you cant run double rollers, the Lt4, or the Extreme duty chain sets unless you convert to a vented opti. To covert, you'll need the vented opti, a 95-97 cover (95 prefered), plug harness, vaccum lines, and a longer cam dowel pin. Do a search if you want a list of all the parts and p/n's
If your planning on running the non-vented opti, the only options are the stock set and the Lunati set. Most agree that the stock set is just as good or better than the Lunati set.
Old Mar 10, 2004 | 01:32 PM
I plan on staying with my non-vented opti, the Lunati is only a little over a 100 i think, anyone have a quote on oem timing chain?
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
