Timing Chain Set?
Old Nov 18, 2003 | 07:15 PM
Xride's Avatar
Timing Chain Set?
Ok, I'm doing a cam swap in my 96, I have less then 60k kms on it, less then 30k miles. and I was told that a new timing chain (maybe set) was a good idea.
first, whats the difference fro ma cahin to a set? and what do I need?
And what set or chain should I look at and get?
I see the the LT4 set is more hten 200 US. I phoned a local place and they said a set shouldnt be more then 60 CAN, thats a HUGE difference.
So can someone clear this up for me? thanks.
Old Nov 18, 2003 | 08:02 PM
will62085's Avatar
lt4 set is a high strength set=more $$$...the set consists of a cam gear, a crank gear, and a timing chain. with only 30k, i would just replace the chain and crank gear (they usually break pulling them off) ...go to your local parts store, it'll be about $40 for the crank gear and chain
Old Nov 18, 2003 | 10:24 PM
Xride's Avatar
Do I need a high strenght set? when would I need one?
So the local set will work? or is GM replacement good enough? (I know a guy at the GM wharehouse here in edmonton)
Old Nov 18, 2003 | 10:33 PM
S.J.S.'s Avatar
At minimum I would go with the GM replacement. If your gonna add more mods down the road I would consider the Extreme duty set.
Old Nov 18, 2003 | 11:29 PM
Xride's Avatar
whats concidered more mods though?
cam, 1.6, and headers at the same time, later down the road lt4 heads and intake. that will be about all.
Will they really break?
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
