Timing chain rubbing?
Old Dec 15, 2008 | 01:04 AM
Prorac1's Avatar
Doing an engine swap and pulled the motor down and put new berings and oilpump in it while I was there. Motor already had a low millage timing set on it so I left it in place. Now the motor is all assembeled on the stand, and when I turn it over by hand a few times (no oil in pan yet) I can hear the timing chain rubbing on the cover. Is this normal when dry? Like all LT1s it had its share of slack, but never made this noise before. Any help would be appreciated. Thanks Eric L
Old Dec 15, 2008 | 01:05 AM
Prorac1's Avatar
BTW, its a stock replacement timing set from GM. Nothing fancy. Eric L
Old Dec 15, 2008 | 01:15 AM
ACE1252's Avatar
Not normal. Need to find out why it's rubbing or what is rubbing.
Old Dec 15, 2008 | 02:58 AM
Prorac1's Avatar
UPDATE: Pulled everything apart and spun motor with timing cover off. The noise im hearing is the timing chain "fluttering" (couldnt think of a better word) from the bottom gear around to the top gear. The noise is chain against gear while its fluttering. Slack is in my opinion excessive (quater inch or more) but well within factory specs. Thinkin im going to pickup a new timing chain and gear set and see how that goes. Eric L
Old Dec 15, 2008 | 04:41 PM
camaro1fastz28's Avatar
you can go to the dealer and just get a chain ther like 40 bux the gear dont wear out that what i did
Old Dec 15, 2008 | 05:29 PM
RUDEDOG's Avatar
How can the chain flutter when you turn it by hand? If you choose to replace it I would replace the set.
Old Dec 15, 2008 | 07:58 PM
RamAir95TA's Avatar
Yeah, definitely replace the whole set. Or consider upgrading to the LT4 set or Cloyes.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
