Timing Chain Replacement Set
Old Mar 22, 2006 | 08:30 AM
Stoopalini's Avatar
I'm removing the timing cover to replace the seals, and figure I should replace the timing chain and gears while I am in there (119k on the clock). I will only be spinning to 6k and putting down around 310-315rwhp after the tune and headers, so I was looking for a good stock-like, bolt in replacement.
I hear Pro Gear is a good option for this, but can't seem to find the part number, or a retailer, for a '96 LT1 set.
Anyone know where I can get a pro gear set, or recommendations for another stock replacement, bolt in, no moding to make it fit, timing chain set?
Thanks,
Thomas.
Old Mar 22, 2006 | 09:54 AM
sabre81's Avatar
Re: Timing Chain Replacement Set
I vote for a stock GM set.
Old Mar 22, 2006 | 02:43 PM
87lt1rx7's Avatar
I dont mean to jack this thread but I am gonna be doing a heads/cam swap. would a stock replacement work fine for this?? I have gone with a stock replacement once before, its a good kit.
Old Mar 22, 2006 | 02:53 PM
ajschult's Avatar
another vote for stock replacement if you dont want to spend the big bucks for a double roller. I hear of a lot of people with high hp cars still using the stock timing set.
Old Mar 22, 2006 | 03:51 PM
Stoopalini's Avatar
Thanks for the input guys. I was leaning towards the Pro Gear set because they are inexpensive. If the stock set is reasonable, I would definitely consider using it instead.
Anyone have a part number for the '96 - '97 stock timing set?
Thomas.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
