Timing chain qustion
Old Feb 26, 2003 | 08:02 PM
Thor39's Avatar
I am rebuilding my 93 lt1. I have the hot cam kit and JE pistons.
Do I really need to put a heavy duty timeing set? or can i just get a new stock timing set ?
Has any one broke a chain on an lt1?
O yea i might be spaying 100 shot of NOS too?
Old Feb 26, 2003 | 08:32 PM
94F1Z28's Avatar
If your going to keep the rpm below 6500 and you don't plan to road race then the stock timing set should be fine.
Old Feb 26, 2003 | 08:39 PM
jmzlt1's Avatar
The hot cam kit is designed for 95 and up lt1's. If you use it on your car you will have to get a 95 timing chain, timing cover and opti. 93 and 94 use a different drive for the opti's than the 95 and up. You might be able to get away with pulling the dowel pin on your hot cam and installing one that is the same size as the stock cam. Check to make sure though. Don't try to remove it with vise grips though, you will ruin the cam. You need to take it to an engine shop for that.
Old Feb 26, 2003 | 08:45 PM
94F1Z28's Avatar
He's is right and wrong,the cam has the long dowel pin but it can be pushed in so you can run it with your stock tining set.
Old Feb 26, 2003 | 08:47 PM
Thor39's Avatar
Are you sure i need to get all that stuff ?
why would i have to whats the diff..
Old Feb 26, 2003 | 08:56 PM
94F1Z28's Avatar
You don't need all those things,if you compare your stock cam to the hot cam you will notice that the dowl pin on the hot cam is longer, all you have to do is push it in until it is the same length as the dowl pin on your stock cam and then it will work.
Old Feb 26, 2003 | 09:00 PM
94 CAMRO Z28's Avatar
Its not a big deal at all, when I did the hotcam kit with my '94 all I did was compare the dowel lengths and tried to tap the pin in farther on the hotcam to match the stock one. I couldn't get it to go in so I just took a dremel and ground it down to correct length, no biggy. As far as a stock timing set, I have been running the hotcam kit for a year now with no troubles. I did buy a brand new stock SET, not just the chain though. Make sure you get the entire set. Anyhow, I've put about 45-50 runs down the track shifting at 6200-6300 without any trouble. Good luck!
Aaron
Old Feb 26, 2003 | 09:23 PM
Thor39's Avatar
Thanks guys for all then help i think im going to get a new stock one becasue i dont have the money to spend for a $300 timeing set. if ya know what i mean
Dustin
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
