timing chain question
Old Oct 20, 2006 | 01:25 PM
JohnnyPappis's Avatar
zanyone have a link to an excellent double roller timing for the 93-94 lt1? cloyes make one? any help would be great
Old Oct 20, 2006 | 01:35 PM
Javier97Z28's Avatar
Moderator
Re: timing chain question
The double roller that 99% of use is the Cloyes 9-3145.
It *will not work* with a non vented opti and factory water pump. There is no double roller that will work with the factory water pump.
You must run:
95-up timing cover
95-up vented opti
Old Oct 20, 2006 | 01:49 PM
You must run:
95-up timing cover
95-up vented opti
not a problem and thanks alot now how would the best way to go about getting the timing cover be and best method for clearence? part #?
Old Oct 20, 2006 | 02:16 PM
Moderator
Timing covers you can pick up in the for sale section all the time for like 20-30$
Clearancing the cover is done the quickest with a die grinder. Just put grease on the chain, present the cover, put a few of the bolts in, turn the engine by hand, see where it rubs. Grind that area down, and repeat until you stop seeing grease rubbed on the cover. Putting the gasket later just gives you that much more room afterwards.
Old Oct 20, 2006 | 02:20 PM
awsome where can i pick up the timing chain a link would be helpful thanks!
Old Oct 20, 2006 | 02:32 PM
Moderator
Summit or Jegs
http://store.summitracing.com/partde...5&autoview=sku
Old Oct 22, 2006 | 04:52 AM
anyone know if a comp custom grind cam has the 95+ dowel ?? if not how can i make it work
Old Oct 22, 2006 | 07:58 AM
Dave89IROC's Avatar
you get the cam yet?
if not, tell them you want a LT1 core, and it will come with the dowel
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
