Timing chain question
Old Sep 6, 2006 | 08:04 PM
RE AND CHERYL's Avatar
I'm about to change the cam in my 94. In the process I'm converting to a vented Opti and installing my CSR electric water pump.
What timing chain can I use?? Because I don't need the pump drive, can I just use a standard double roller timming chain?? Just looking for something cheaper than the expensive LT1 parts if possible/
Re'
Old Sep 6, 2006 | 08:16 PM
Heatmaker's Avatar
Advanced Member
Re: Timing chain question
You can use the 79 dollarr double roller, but the timing cover needs to be adjusted a bit for clearance. I'm sure there's other "single" timing chains that will work without being modified though.
Old Sep 7, 2006 | 02:05 PM
any other recomendations.
Old Sep 7, 2006 | 04:00 PM
AZ2ENVY's Avatar
you can use an OEM 95-97 style chain set . Try getting it from dal
cuz thats the cheapest for OEM .
Old Sep 17, 2006 | 02:25 PM
AlwaysCode390's Avatar
I was just looking at Summit and the Cloys Double Roller #3145 is what everyone is recommending $79.88 ( factory roller ) , BUT the one below it #3151 says NEW LT1/LT4/L99 (95-up) is $349.95 ....WTF is the difference?! ---
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
