Timing Chain options?
Old Feb 5, 2003 | 09:40 AM
All_Z_Way's Avatar
I am about to install the Xe230/236 cam with a set of P&P heads.
I am getting conflicting oppinions on a timing chain.
Most say just put in a new timing chain and you will be fine.
Other say you really need a heavy duty chain - either the LT4 extreme duty set or others.
What options are out there besides the LT4 set?
Old Feb 5, 2003 | 09:46 AM
Ken95Z28's Avatar
LT4 Extreme Duty is very $$$.
I installed the Cloyes Double Roller, you must use a electric pump in order to use it. $85 chain $130 for pump versus $250 or more for Extreme Duty chain.
I know there must be some other options out there, but this is what worked for me.
Old Feb 5, 2003 | 10:25 AM
All_Z_Way's Avatar
I really didn't want to go to an electric pump, especially since I do a lot of road course duty and I am not sure it would to the job cooling enough.
But I am sure curious about other options. I would like to avoid the $$$ LT4 set.
Old Feb 5, 2003 | 01:33 PM
nateh's Avatar
I am only changing the chain with a GM stock replacement. It's all you really need.
Old Feb 5, 2003 | 01:40 PM
IDOXLR8's Avatar
Are you planning on revving the car high?? If you are going to do roadracing I would recommend getting an LT4 extreme Timing chain.
Old Feb 5, 2003 | 02:32 PM
All_Z_Way's Avatar
I will be mostly open tracking the car and revs will reach 6200-6300, but not very many hanging high RPM's.. just jumps up that high.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
