Timing chain off a tooth?
Old May 6, 2007 | 10:15 PM
henryz28's Avatar
I did a cam install about 1 mounth ago and ever sence the car has been running like crap;It cant even spin the tires no power below 2500rps.It dose run rough up untill it hits 3000rps.I am thinking the timing chain was put in off a tooth;The only reason I havent tore in to it yet is because last weak I took off the opti cap and turned the motor to tdc.At tdc the opti looked like it was fireing on number 1; but how far off would it be if it was only off 1 tooth off would I even be able to notice the opti is off?Thanks
Old May 6, 2007 | 10:18 PM
henryz28's Avatar
The car is a 1996 camaro z28 lt4 hotcam kit with a dubble timing chain.I dident have the crank shaft sensor tuned out could that cause my problem?
Old May 7, 2007 | 01:08 PM
Dave1980's Avatar
Are you getting codes?
Old May 7, 2007 | 02:04 PM
henryz28's Avatar
No codes except for the crank shaft sensor;Caused by the dubble timing chain.
Old May 7, 2007 | 04:55 PM
1racerdude's Avatar
Crank sensor is used for missfire only. One tooth would do it. Check the valve adjustment before tearing it down.
Go to Shoeboxe's site and get the procedure.
Old May 8, 2007 | 09:27 PM
henryz28's Avatar
It was off more than one tooth it was off 3 teeth.The car runs great now.Thanks
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
