Timing Chain Need Advice On Clo-9-3145
Old Mar 4, 2006 | 10:55 AM
playa7970's Avatar
I JUST ORDERED THIS FROM SUMMIT AND HAVE A 94 Z WHAT WHAT ELSE AM I GOING TO HAVE TO GET FOR IT BESIDES TAKING A DREMEL TO IT? SOME INFO WOULD BE GREAT THANKS! ( SORRY ABOUT THE CAPS JUST NOTICED IT)
Old Mar 4, 2006 | 11:03 AM
RamAir95TA's Avatar
Re: Timing Chain Need Advice On Clo-9-3145
Ugh...you won't be able to use it without some extensive modification. You'll need to remove the water pump drive (which requires use of an electric water pump), you need a vented optispark setup (which requires a longer dowel pin [new camshaft], vacuum lines, wiring connection, and a 95 year timing cover. Not to mention needing to possibly grind the timing cover for the chain to fit.
Maybe want to save the receipt if you didn't plan on doing all of this.
Old Mar 4, 2006 | 11:06 AM
playa7970's Avatar
sorry i forgot to mention that i have the le2 setup from lloyd and came with a custom cam to work for my setup but dont know if its adaptable to that cam??
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
