timing chain install ???
Old Jan 1, 2009 | 11:37 AM
PHINES LT1's Avatar
so i have read my shop manual and shoebox's website, a huge help but my question is this. when you remove the timing set for a cam swap it is removed with #1 cylinder at TDC. when you replace the timing set the cam sproket is installed so that the timing marks make it #6 cylinder at TDC. is this correct or am i not reading this right? thanks again.
Old Jan 1, 2009 | 12:07 PM
Stl94LT1's Avatar
Just line up the dots, rotate the engine a couple of times to make sure they are still aligned, and you will be fine. Don't let the TDC confuse you. One and six are at TDC at the same time, just different strokes (compresssion, exhaust).
Old Jan 1, 2009 | 04:12 PM
I already told you it did not matter where it was when you remove it. Just line the dots up when you intall it.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
