Timing chain cover leaking - time to do other things?
Old Jan 16, 2006 | 08:42 PM
Scream And Fly's Avatar
Okay, so I'm leaking some oil from the timing chain cover. I guess it's a waste just to fix the leak by itself, right? Is this a chance to do something else while I have it apart?
Old Jan 16, 2006 | 09:00 PM
OBE1 95Z28's Avatar
Re: Timing chain cover leaking - time to do other things?
The cam is located right behind it
Old Jan 16, 2006 | 09:23 PM
BLUE95M6's Avatar
Unhappy Re: Timing chain cover leaking - time to do other things?
You might as well change the timing set while you have it apart and maybe consider an electric water pump.
95z 3 thrown rods second pass after rebuild
Old Jan 17, 2006 | 12:41 AM
ponyackn's Avatar
LOL, exactly my thought too. I waited with a horrible leak at the oil pan gasket for who knows how long. After unsuccessful attempts to fix the leak myself for free, I figured, let's do a large cam and head swap I guess you also might as well do the timing chain and electric water pump too.
Old Jan 17, 2006 | 12:59 AM
sssalah's Avatar
Good god, the guy has an oil leak....I agree change the cam, springs, rockers, pushrods, timing set....
Old Apr 16, 2006 | 06:48 PM
unTAmedLS1's Avatar
Then that means you have to pull the intake to get at the lifters so you might as well pull the heads after that too
Old Apr 16, 2006 | 07:29 PM
3gc's Avatar
3gc
At the very least all new seals for the timing cover and a new chain if you have a bit of miles on your engine. But if it's in your budget and you feel confident enough to do it, throw a nice streetable cam in there.
Old Apr 16, 2006 | 07:55 PM
Randomsoleil's Avatar
what stinks is that mine didnt start leaking till after i did a cam swap...i heard the timming seal was a pain..any tips to help slow the leaks?
Old Apr 16, 2006 | 08:49 PM
snakeatinZ's Avatar
Well put!!!
Steve
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
