Timing chain cover leaking - time to do other things?
Okay, so I'm leaking some oil from the timing chain cover. I guess it's a waste just to fix the leak by itself, right? Is this a chance to do something else while I have it apart?
You might as well change the timing set while you have it apart and maybe consider an electric water pump.
95z 3 thrown rods second pass after rebuild
Re: Timing chain cover leaking - time to do other things?
Originally Posted by OBE1 95Z28
The cam is located right behind it
I guess you also might as well do the timing chain and electric water pump too.
At the very least all new seals for the timing cover and a new chain if you have a bit of miles on your engine. But if it's in your budget and you feel confident enough to do it, throw a nice streetable cam in there.
what stinks is that mine didnt start leaking till after i did a cam swap...i heard the timming seal was a pain..any tips to help slow the leaks?
Steve
