Timing Chain Cover
Old Dec 30, 2005 | 11:57 AM
Temple's Avatar
Timing Chain Cover
Doing a cam swap and going with the Cloyes True Double Roller Timing Chain. I already have an electric WP, so I just removed the old water pump drive shaft. Can I leave the hole in the block open or does it need to be plugged?
I did some research and found out that I can just plug the hole in the timing chain cover for the water pump with a freeze plug but don't know about the hole in the block.
Old Dec 30, 2005 | 12:50 PM
97WS6SCharged's Avatar
Re: Timing Chain Cover
The hole in the block you can leave open. Just make sure you plug the timing cover really well. I'm having my new cover tig welded just to be sure.
Old Dec 30, 2005 | 01:25 PM
Temple's Avatar
Awesome..Thanks for the quick reply!!
Old Dec 30, 2005 | 06:01 PM
95RagtopTA's Avatar
I agree, hole in block is ok. Little tip--the freeze plug is a PITA to find, I couldn't locate one. Instead, use a 1/2 dollar (may have to go to a bank to get one ) and some JB Weld (Autozone, Napa). The 1/2 dollar fits perfectly, and looks kinda cool .........
Old Dec 30, 2005 | 07:46 PM
93 4mula's Avatar
What????????? Do you put the 1/2 dollar in first then jb weld on outside? Your not worried about the jb coming out?
Old Dec 30, 2005 | 10:49 PM
1racerdude's Avatar
Heads or Tails....
Old Jan 13, 2006 | 12:34 AM
Bersaglieri's Avatar
Originally Posted by 1racerdude
Heads or Tails....
I got a good chuckle out of that one. I am pretty sure I just left the WP gear in there...
-Dustin-
Old Apr 16, 2006 | 06:50 PM
unTAmedLS1's Avatar
I used a quarter with some rtv and jbweld lol
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
