timing chain cover 3pin black female connector??
I just bought a '94 Formula that will not run because of an alleged ignition problem. As I was checking it out, I found a black female 3 pin connector on the bottom passenger side of the timing chain cover. The last 4th gen I had was a '93 Z28 that I sold about 8 years ago so I'm having to relearn a few things. Is there a plug that connects to this? If so, I can't find one. I don't remember this on my '93.
Thanks.
Rob
Thanks.
Rob
The only device that is physically located on the timing cover is the crank position sensor, but they were only used 96/97. Is it possible someone swapped in a 96/97 engine?
http://www.enginebuildermag.com/Cont...0000003989.gif
