timing chain choices
Old Oct 31, 2006 | 09:55 PM
jeepbeast's Avatar
just wondering about the timing chain on my 94 z. i am going to do a le1 or 2 heads/cam. are there any other timing chain options for my non-vented opti? or do i have to go with a stock one with the stock water pump? if i go to an electric water pump, are there any options to go with there?
i am not going to do the vented opti conversion. any way you guys can point me to. i've searched and really haven't found any answers...
Old Oct 31, 2006 | 10:24 PM
seawolf06's Avatar
LT4 ED. I don't know if you can use the cloyes double roller with a unvented or not, but you definitely need an ewp for that.
Old Oct 31, 2006 | 11:19 PM
Bawls's Avatar
I just went with a stock replacement. It lasted 154k very abused miles, might as well go with that. (I'm not replacing the chain because I have to, only replacing it because the opti went and since I have it off, might as well)
Also, doesnt the LT4 ED cam sprocket have a center hole so the vented optis shaft go straight through, since they're ran off the cam's dowel pin?
Pretty sure the 93-94's optis are ran from a "driveshaft" that is keyed to the 93-94 cam sprocket.
If that's the case, without doing the conversion, wouldnt your only option be a 93-94 cam sprocket?
Old Nov 1, 2006 | 06:53 AM
Your stuck with a stock type set, unless you convert to a vented opti. You can't use an LT4 or double roller.
Old Nov 1, 2006 | 07:37 AM
Javier97Z28's Avatar
Moderator
Correct! (of course )
Old Nov 1, 2006 | 08:31 AM
JasonK94Z's Avatar
I thought the summit catalog listed a Lunati chain for the earlier LT1's? I wish i had my catalog here.
Old Nov 1, 2006 | 08:35 AM
Schweet97Z's Avatar
it only lists for 92-93....but the part number is LUN-93094
Old Nov 1, 2006 | 09:04 AM
arcticz28the383's Avatar
I have a lunati on my 94 engine, 4500 abused miles, so far so good.
Old Nov 1, 2006 | 09:23 AM
It's still a "stock-type" cam gear. Ever look at the Lunati set? The cam gear looks just like a stock gear, down to the GM stamping on it.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
