Timing Chain - CC306 - Opti Conversion
Old Nov 4, 2006 | 10:53 AM
Bersaglieri's Avatar
I'm getting pretty close to putting a CC306 in the Z28 and I had a few questions about timing chains. I have a vented opti conversion kit, the cover, opti, harness, vent tubes, etc. I was planning on running a Cloyes True Double Roller set. But was wondering if the Cloyes and a vented opti would work if I bought a CC306 that was in a 94. From my research I think that the 94 Cam would need to have the front hole machined larger and the dowel pin made longer. At first I thought just the dowel pin needed changed which would be easy, but how easy is it to machine the larger whole in the front. Anyone have experience with this?
-Dustin-
Old Nov 4, 2006 | 12:02 PM
Mtrhds94Z's Avatar
I would think the aftermarket cam would already be drilled, probably all would be drilled..
Why not ask the seller, or try to get a pic and see?
Not having one I can't say for sure..
Old Nov 4, 2006 | 12:28 PM
I would also think that the cores for the Comp LT1 cams would all be the same (drilled large enough for the vented opti).
Old Nov 4, 2006 | 01:38 PM
First, thanks alot shoebox and Mtrhds94Z for making that point. Thats what I was wondering, it would make sense that they are all the same and you only adjust the dowel pin for your application. But I was looking at the pictures on the opti swap page " http://para.noid.org/~muttvette/opti.html " not thinking that they were probably stock cores.
With this said, is there a standard size dowel pin I can order to replace the 94 length one in the CC306 or can I just pull it out to the length necessary? I work for a company I can order dowel pins through, or should I get one from Comp or GM?
Thanks again guys.
-Dustin-
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
