timing chain?
Old Feb 22, 2010 | 11:02 PM
ray396's Avatar
Question timing chain?
Hi, OK guys, what timing chain set do you guys use. i need to install my cam 4 degrees advanced.Thanks Ray
Old Feb 23, 2010 | 04:52 PM
gillta95's Avatar
http://performanceparts.com/part.php?partID=245277
I'm using this cloyes setup but the lt4 is good too. Depends if you want to grind the timing cover, then a regular sbc can be used.
Old Feb 23, 2010 | 06:04 PM
RamAir95TA's Avatar
You don't provide nearly enough information for anyone to give you valid info.
What year car? What type of optispark drive? OBDI or OBDII? Are you looking for a stock replacement? Timing should be left up to the PCM and not manually adjusted (unless you are running a carb setup).
Old Feb 24, 2010 | 07:17 AM
Slick-Z's Avatar
True that because if you mess with the timing manually it might not be starting up again. Should be left up to the computer in 93-97 camaros
Old Feb 24, 2010 | 03:41 PM
ray396's Avatar
Cool
Hi, OK,.I will line up the Dots and leave it that way.Thanks Ray
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
