Timing Chain
Old Feb 8, 2007 | 05:03 PM
Chuckels's Avatar
Timing Chain
Can you use the the chain for the LT4/LT1 Extreame duty (pn 14088783) set on stock LT1 gears? My motor only has 70k miles on it, I dont see a need to replace the gears but please inform me if wrong. Also the chain sold in the extreame duty kit is just a SB Chevrolet Roller Timing Chain. This would be accompanying a hot cam that will not spin any higher than 6200ish rpms.
Old Feb 8, 2007 | 05:07 PM
No, the chain is not compatible. The ED chain is a roller chain and the stock chain is a link belt. IMHO, you should always change the timing set, not individual pieces. A wear pattern is created between all parts as they age.
Old Oct 7, 2008 | 11:59 PM
Highlander's Avatar
is this extreme duty an OEM GM part??? it may be made by cloyes or what not...
Anyways.. is there a part number for the set???
Old Oct 8, 2008 | 06:51 AM
GM PART # 12370835 as shown in the part numbers list on my Tech Page.
Old Oct 8, 2008 | 08:47 AM
Highlander's Avatar
Thank you! What about the oversize crank pulley... is it really needed?
Old Oct 8, 2008 | 10:18 AM
I couldn't tell you. I have never used the set.
Old Oct 11, 2008 | 07:05 AM
Don 97 SS's Avatar
I was impressed with the design of the GMPP LT1/LT4 ED set (over the oem version). I installed mine years ago while doing a fresh cam. I think you would be pleased.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
