timing chain
Old Jan 9, 2007 | 12:53 PM
12345678910's Avatar
timing chain
i am about to do an le1 swap on my 95 camaro and was wondering when i change the timing chain can i just replace the chain or do i have to get the gears too. also the chain would be from an lt4 so if i can just swap the chain is this chain alright.thanks
Old Jan 9, 2007 | 01:02 PM
seawolf06's Avatar
The chain and gears should be swapped as a set. I think it's kind of like rear end gears, once the wear pattern is established, you don't want to just change one gear, you want to change both if that's required.
Old Jan 9, 2007 | 01:07 PM
TobyZ28's Avatar
You cant put an LT4 chain on an LT1 sprocket either
Old Jan 9, 2007 | 01:34 PM
2000GTP's Avatar
The LT4 chain is not the only thing that is different in the set either. The LT4 cam sprocket went to a solid mass design versus the webbed design on the LT1 set: http://www.grandsportregistry.com/lt1vslt4.htm
Old Jan 9, 2007 | 02:49 PM
thanks for the help
Old Jan 9, 2007 | 02:54 PM
any sugestions on what timing setto use, i know cloyes has one for 80 is that alright to use
Old Jan 9, 2007 | 06:53 PM
seawolf06's Avatar
If you use the cloyes, you'll need a 95 vented setup and an electric waterpump.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
