timing chain
Old Apr 29, 2006 | 09:16 PM
94formulacoup's Avatar
timing chain
im installing an electric water pump so i can do away with the stock timing chain.just need to know what chain to get and what do i use to plug the old water pump hole?any info will be greatly appreciated!
thanks
Old Apr 30, 2006 | 06:50 AM
sssalah's Avatar
Re: timing chain
Unless you're prepared to swap to the vented opti, you're stuck with the stock timing chain.
As for the hole in thetiming cover I welded mine.
Old Apr 30, 2006 | 07:28 AM
Re: timing chain
thanks,ive already converted to the newer vented opti.what timing chain did you use?
Old Apr 30, 2006 | 09:09 AM
BlackDog's Avatar
Re: timing chain
These are your only choices for a 94 motor.
The Cloyes - CLO-9-9100
Lunati - LUN-93094
or the factory replacement.
The Cloyes and Lunati will state that the parts are for 92-93 only. I called them directly and they both said that they are a direct fit for the 94 motor. The reason that they do not include the 94 year is that some late model 94's came with the 95 setup.
You would think that they would say that it would fit some early 94's. But they don't.
Old Apr 30, 2006 | 09:35 AM
96WS6TA's Avatar
Re: timing chain
If you are going to remove the water pump drive gear, you can use any timing chain for a factory roller cam motor. That is what I did. The chain I used was for an older roller cam 350 (like say a 1990 Z28). That was on my 96 where the opti is driven off of the camshaft dowl and the timing gear doesn't have anything to do with it. To plug the hole in the cover, try to find a "freeze plug" or the like to fit in there. I found one close and used silicone to seal it in there. It has been a few years and no leaks.
Old Apr 30, 2006 | 01:26 PM
jasonisdn's Avatar
Re: timing chain
have you had your zz9 cam out of your car since you installed it? i took mine out the other day to do my 396 and the zz9 was eat the **** up. i have some pics i'll post a link to in a few hours. might want to check it if its not your daily driver.
Old May 1, 2006 | 01:22 AM
sssalah's Avatar
Re: timing chain
Using the cloyes 3145 timing set, this is discribed as timing set for factory roller small block.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
