timing chain?
Old May 1, 2005 | 03:45 PM
1997formula's Avatar
timing chain?
I'm doing the hotcam kit and wanted to know if you guys think I should get a new timing chain? the engine has about 20,000 miles on it. Also can I use the stock push rods? Thanks
Old May 1, 2005 | 04:01 PM
CamaroBoy96Z28's Avatar
Re: timing chain?
You could probably use the stock timing set and be ok if you dont plan on too much more. Personally, I'd drop the $200 on the LT4 ED timing set. As for pushrods, get stronger ones. No sense in putting money into the motor and put less than optimal parts back in.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
