SES Light
Old Nov 24, 2003 | 08:56 PM
z28jaz's Avatar
SES Light
I have been getting an SES light randomly for the last month. Finally I went down to Checker and and borrowed a scanner. Found out I am getting a code 34 which seems to do with the MAP sensor and a code 24 for the vehicle speed sensor.
With this information I would like to know what I should and what solved this issue if you have had it.
Thanks for the help.
Old Nov 25, 2003 | 08:00 AM
z28jaz's Avatar
ttt
Old Nov 25, 2003 | 08:18 AM
You need to check the wiring to be sure voltage and ground are ok. Maybe you have sensor problems. A scan tool would be helpful by letting you watch the readings the pcm is getting.
Some info here might be helpful.
Dzmaro
May 7, 2015 09:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
