Timing Chain
Old Jun 30, 2003 | 09:06 AM
DamianLT1's Avatar
Exclamation Timing Chain
I need advice on which timing chain to buy. See Sig & I will KEEP the stock water pump. What are my option beside the LT4?
Old Jun 30, 2003 | 11:24 AM
PoorMan's Avatar
The others I have seen are Luntai (sp?) and Comp cams sets but they are around $600 bucks. So the LT4 is the only decent one out there.
Jeff D.
Old Jun 30, 2003 | 11:31 AM
Carlos01SS's Avatar
Jeff D.
$600.00 bucks for a TIMING CHAIN???
What's it made out of??? Platinum???
Dang...
Old Jun 30, 2003 | 12:50 PM
DamianLT1's Avatar
Since I'm going to change cams I need a solid affortable one.
Old Jun 30, 2003 | 12:58 PM
GREGG 97Z's Avatar
Lunati now has one for the LT1, I don't know how much stronger it is than stocker but it's another option. It's in the latest Summit catalog for around $107 or check online with them.
Old Jun 30, 2003 | 01:23 PM
CANTONRACER's Avatar
I just put a Cloyes true double roller timing chain for $70 I think.
Old Jun 30, 2003 | 01:33 PM
nateh's Avatar
The stock chain will stand up to a lot. There isn't a reason to spend a lot of extra money until you have some serious power.
Old Jun 30, 2003 | 01:54 PM
My stock chain was a loose as they get. I was actually wondering if my timing was even close to what it was supposed to be with it.
Old Jun 30, 2003 | 01:59 PM
GREGG 97Z's Avatar
I thought the same thing. I removed my stocker at 57K recently and was shocked how loose the thing was, lots of slack in it. I went with the Cloyes double roller also.
Old Jun 30, 2003 | 02:11 PM
DamianLT1's Avatar
I think the Clones one is for an electric pump. I rather stay with the stock one.
Old Jun 30, 2003 | 02:54 PM
atljar's Avatar
The cloyes you will need an electric h20. Your options are running the stock chain, with a slightly oversized sprocket to take up the slack, or to run a lt4 chain which is beefier and a little tighter.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
