timing chain
Old Mar 30, 2003 | 10:58 PM
93.FORMULA.WS6's Avatar
timing chain
hey is there a difference between the 93 LT1 timing chain and the 94 LT1 timing chain?
Chris
Old Mar 30, 2003 | 11:06 PM
Nope.
Old Mar 31, 2003 | 01:58 AM
Wild1's Avatar
With you're mods, I'd look into a heavier chain like the LT4 Extreme Duty Timing Chain. I know it isn't what you asked but since your engine looks stout, it should have a good chain.
Old Mar 31, 2003 | 06:51 AM
Smoke T/A's Avatar
Talking
Why waste the money on the lt4HD unit when he could get a double roller for about $250 less and have a stronger chain???? He already has a electric h20 pump.
Joe
Old Mar 31, 2003 | 11:53 AM
Wild1's Avatar
I can see that if he has the electric water pump (listed in the sig) then the double roller would be a better option. But, with a double roller, won't you need a new timing cover too?
Actually, he hasn't indicated if this is for his car or a buddy's.
Old Mar 31, 2003 | 12:18 PM
Smoke T/A's Avatar
Well I had a cloyes DR behind my 95 timing cover with no problems. But i have heard some people have to grind a little for it to clear.
Old Mar 31, 2003 | 12:45 PM
Wild1's Avatar
Cloyes... that's quality. I've heard some company sell the Cloyes for $400. I think it was Speedomotive. I'll be doing mine this summer. Any good leads?
Old Mar 31, 2003 | 01:50 PM
DMartin's Avatar
Four hundred dollars is alittle high. You can get the same chain from summit or jegs for like eighty-ninety dollars. Just order the one for the third gen(part #9-3145?). Its a true double roller. Install it straight up with no advance or retard. What I dont understand is that you can do this and an electric water pump set up for about half the cost that will beat the hell out of the factory chain and pump.
Old Mar 31, 2003 | 02:48 PM
Wild1's Avatar
I don't mean to be a thread stealer, but since you're answering some good question. I've got another....
How is the electric pump in stop-and-go traffic? Does it very speed with RPMs?
Old Mar 31, 2003 | 02:54 PM
mobleman's Avatar
The electric pump does not vary speed with rpm, Had mine on for a year now with no problems (yet)
I had a question about the double roller chain from jegs, does that include the sprockets as well?
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
