CC 242/248 vs. 248/254
Old Mar 28, 2003 | 09:59 PM
Mullet Z28's Avatar
Both are shelf cams:
242-248/.570-.576/112
vs.
248-254/.576-.582/112
Who's run either of these solid rollers? This is going in a 12:1 383. I want to run the bigger cam, but if it needs to be shifted after 7000RPM, no can do because of the stock PCM.
Old Mar 28, 2003 | 10:34 PM
Ai's Avatar
Ai
Well that really depends on the entire combination of parts, heads/intake/exh, and chassis setup.
If you're looking for a shelf solid, if it were mine with a nice set of LT1's, I'd probably run something like a 252/258-110
Old Mar 28, 2003 | 11:24 PM
adrenaline24's Avatar
When I finally get all the parts collected for my 383 its going to include 248-254 cam.
Old Mar 29, 2003 | 03:31 AM
Mullet Z28's Avatar
They're locally ported stock castings. The shop claims 290 CFM, so I take it they really flow 250 - 260. The intake manifold is port matched to the heads and the exhaust is a Hooker long tubes and dumping out a cut out. And oh yeah, 4.10 gears and no weight removal.
The biggest concern is compatability with the stock PCM. Comp lists the operating range as 3000 - 7000 RPM. Does that mean power peaks at 7000 or that's where it should be shifted?
Thanks.
Old Mar 29, 2003 | 03:42 AM
mastrdrver's Avatar
I know Kmook was going to run the smaller cam in his 350 before things went down hill. I would call Comp and see what they have to say or maybe TR, CMotorsports, etc.
Old Mar 29, 2003 | 07:36 PM
Mullet Z28's Avatar
Phil?
Old Mar 30, 2003 | 02:12 PM
kmook's Avatar
Advanced Tech Moderator
I ran a 242/248 585/586 112lsa solid roller in my stock 350. I cant comment on if it was to big or to small since i never got a chance to run it hard.
Old Mar 30, 2003 | 06:06 PM
Mullet Z28's Avatar
Originally posted by kmook
I ran a 242/248 585/586 122lsa solid roller in my stock 350. I cant comment on if it was to big or to small since i never got a chance to run it hard.
What RPM did you shift it at?
Old Mar 31, 2003 | 08:35 AM
kmook's Avatar
I meant that i never got to run it hard or see where peak HP was to shift at, the engine grenaded before i ever got to look at that aspect.
Old Mar 31, 2003 | 02:49 PM
solid95z's Avatar
Is the 122lsa a misprint?
Old Mar 31, 2003 | 02:55 PM
kmook's Avatar
Sure enough Suppose to say 112.
whitehooptie
Aug 17, 2015 08:35 AM
NewsBot
Jul 3, 2015 02:10 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
