Timing Advance
Old Mar 17, 2006 | 10:07 AM
user 647483's Avatar
Timing Advance
Does anyone run mechanical advance on their LT1s or is it all controlled in the computer anymore?
Old Mar 17, 2006 | 10:26 AM
disco192's Avatar
Re: Timing Advance
As long as you are running an opti... it is all in the computer. If you run a distributor from the cam, you could do a manual advance... but its all in the computer stock.
Old Mar 17, 2006 | 10:31 AM
Re: Timing Advance
So even when I swap out the opti for an MSD unit, it will still be run by the computer. I can deal with that.
http://www.jegs.com/webapp/wcs/store...hItemId=312935
Old Mar 17, 2006 | 10:37 AM
Javier97Z28's Avatar
Moderator
Re: Timing Advance
That's not a whole opti you realize right? Just a cap and rotor.
The complete MSD replacement opti has not been released, but it would not make a difference how it is done, all timing advance is done via PCM.
You *can* advance your cam to crankshaft timing, but the only people who do that in our cases are people trying to get their cam to degree properly.
Old Mar 17, 2006 | 10:52 AM
Re: Timing Advance
Will it resove the issues people have been having with the non-vented opti?
Otherwise, I'm not going to bother to install it.
Old Mar 17, 2006 | 12:39 PM
SoloExceptional's Avatar
Re: Timing Advance
Summit# MSD-8381
Isn't that the whole opti?
Old Mar 17, 2006 | 12:52 PM
Moderator
Re: Timing Advance
Originally Posted by SoloExceptional
Summit# MSD-8381
Originally Posted by Summit
Estimated Ship Date: 5/15/06
That's a release guesstimate, they have no real idea when it will be out.
Old Mar 17, 2006 | 01:08 PM
Re: Timing Advance
That would explain the $350 price difference.
My bad for not reading. Luckily Jegs has a very liberal return policy.
Feffman
Oct 9, 2015 05:42 AM
armedtrigger
Feb 24, 2015 08:30 PM
squarehead
Jan 15, 2015 07:02 PM
Noenav
Dec 6, 2014 07:35 PM
squirrels
Jul 13, 2002 01:58 AM
