Times with this combo
Old Apr 28, 2004 | 03:39 PM
lookingformore's Avatar
Re-built motor..stock bottom end......305 compcam...AFR heads 180..with 1.6 RR's....basic stall on convertor...26-2800.....4.10's in rear.....FLP long tube headers.......any thoughts on times in the 1/4.........
Old Apr 28, 2004 | 06:31 PM
not expecting too much just into the 12's somewhere
Old Apr 28, 2004 | 07:46 PM
drewstealth's Avatar
if you can get traction you should be somewhere in the mid 12's.
That is assuming you have a CAI and a cutout or good catback.
Old Apr 28, 2004 | 08:36 PM
1984camaroz28's Avatar
ur like 10 min from me
Old Apr 29, 2004 | 01:06 AM
rock1501's Avatar
Low 12`s with a street tire and high 11`s with a slick
Old Apr 29, 2004 | 05:04 AM
1982z28with18s's Avatar
Ditch the cam and afr's and get a set of Lloyd elliot heads/cam for cheaper. On the stock bottem end and with a 3000 stall, 3.73's, and et streets(and the other basic bolt ons) I ran 11.84 at 114.7 with his heads and a cam smaller than all 3 he offers now.
Old Apr 30, 2004 | 10:16 AM
I'm confident in the combo
Already ordered the AFR's....and just need to match a cam up to them......and will probably up the stall in the trans to 3000......heard a lot of positive things about the AFR's from people in the business and people i trust......there are pricy but i so is racing......about the feedback....i was just hoping for mid to high 12's......so of you guys think even better times???.....sounds good to me......if i ran slicks would i need to upgrade the rear end axles....or should stock hold everything together.....
Old Apr 30, 2004 | 10:59 AM
BUBBA's Avatar
Sounds like a good combo to me. But as with most of the cars on this site, if you plan on getting on it often, in my opinion, you should plan on beefing up the rear to a 12 bolt or 9" ford. JMHO
Most of us spend all our money and time on increasing the power, but if you can't put it to the ground without breaking the rear end, it is just a matter of time before you wind up spending 2500-3000 on a bullet-proof rear end. JMHO
Old Apr 30, 2004 | 11:35 AM
stereomandan's Avatar
Those mods will get you right where you want to be for times, with good driveability also.
Beware that you may have a hard time hooking up with a 4.10 rear end because you will have a mountain of TQ in 1st gear. If you put on slicks to compensate you might be saying bye bye to your rear end like others have said.
Just my thoughts. I could be wrong.
Have fun.
Dan
Old Apr 30, 2004 | 04:22 PM
What happens
What actually breaks in the rear..because i already went through my stock rear end gears.They broke on the first couple of runs while stock......and got the 4.10's put in with a good Eaton Posi unit......What actually breaks.........
Old May 7, 2004 | 06:58 PM
Still wondering
Wondering if you guys can actually explain what breaks in the rear.....
Old May 7, 2004 | 07:13 PM
sean1997ws6's Avatar
In most cases with 10Bolts its the teeth on the ring gear. they will get some teeth stripped off. Best way to keep your 10Bolt a little longer would be to hang around a lower gear ratio such as 3.23 or 3.42. Thats beacuse the lower you go gear wise the ticker the gear and teeth are so you will have less of a chance of breaking them. I should take my own advice snapped teeth on 4.10' once and 3.73's twice Need that 12Bolt
oldschool
Feb 9, 2016 09:21 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
92ragtop
Dec 27, 2014 01:56 PM
ChameleonGreen
Sep 2, 2002 05:15 AM
johnsocal
Aug 29, 2002 10:01 AM
