Time for the high mileage oil?
Old Jan 5, 2005 | 03:36 AM
  #16
Cerwin Vega Fan's Avatar
Re: Time for the high mileage oil?
So if I change to Mobile 1 what are the odds I will develop leaks?
Old Jan 5, 2005 | 03:37 AM
  #17
93turbo5oh's Avatar
id wager $20 that it will
Old Jan 5, 2005 | 03:54 AM
  #18
Lower's Avatar
I'd bet it won't.
Cerwin Vega Fan, be sure to search the board for the word "oil" and the username "Patman". A ton of great info to be had.
Old Jan 5, 2005 | 04:24 AM
  #19
93turbo5oh's Avatar
Originally Posted by eagleknight97
Not at all. SAE 30 is a straight 30 weight oil, meaning it is always 30 weight, which isnt really good in cold weather. 0W-30 is 0 weight cold, and 30 weight hot. At least thats what im under the impression it means.
0w30 means its a 0 weight that will not thin out more then a 50 weight when hot.
http://www.atving.com/editor/techtips/oiltch.html
Old Jan 5, 2005 | 07:31 AM
  #20
ZyberMunster's Avatar
94 LT1 with 115K here...Mobil1 5W30 every 2500 since new without fail, NO oil burning, NO leaks, NO engine gunk and NO problems.
Laterzzz...
Old Jan 5, 2005 | 09:49 AM
  #21
eagleknight97's Avatar
Originally Posted by 93turbo5oh
i ran castrol when it was a true synthetic, before they changed it. i was using the stuff when it came out in 1990. M1 used to be a true synthetic too. you might want to do some searching yourself. maybe talk to some oil engineers that are unbiased. i can give you some telephone numbers if you like.
Have you ever had any oil analysis tests done? If you have, or have read up and researched different oil analysis's then you would know that for the LT1, German made Castrol Syntec 0W-30 is the best oil for the engine. It produces the least amount of wear on the engine. But you have phone numbers that you can give me, so I guess you know everything.
Old Jan 5, 2005 | 10:04 AM
  #22
93turbo5oh's Avatar
i dont know everything. thats the whole point. i get my information from people that make the real synthetics. the stuff that doesnt start out as mineral oil base stock.
Old Jan 5, 2005 | 10:50 AM
  #23
Camaro97Z28's Avatar
I use amsoil, cuz I'm friends with a distibutor! hehe.
Old Jan 5, 2005 | 05:18 PM
  #24
SixSpeedShifter's Avatar
I switched to Mobil 1 synthetic when i got the car at 60k. I'm just about to roll over 100k and had ZERO leaks.
Old Jan 5, 2005 | 05:35 PM
  #25
LT1Squirrel's Avatar
i switched to M1 at about 125k, no probs whatsoever
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
