Tilt Steering Column/ REplace and Turn Switch??
Old Apr 21, 2003 | 05:29 PM
djk19's Avatar
I have a95 z-28.
The Tilt column has some "springy" give to it. it pulls down and to the left side slightly when pulled hard. I drove a 99 LS1 the other day and the steering column had absolutely NO give to it. I want to make mine this tight. and...
On another note: My directional lever is broken. the turn signals work btu I can't switch my high beams off. I checked out GM and the part is $136 dollars. Anyone have a very nice condition tilt for Lt1 with nice tight working lever? I will buy it.
What is the easiest solution to these two problems. I was figured I could just thorw in a new column and sell this one that i have and end up not spending a lot.
Old Jul 25, 2004 | 11:06 PM
firehawkformula's Avatar
Re: Tilt Steering Column/ REplace and Turn Switch??
I have the same problem in my 95, when I can pull the wheel down and to the left, any ideas whats broken?
Old Jul 26, 2004 | 09:19 AM
Slop in the tilt mechanism. Seek out TABAHR in the General F-body Tech forum. http://web.camaross.com/forums/showthread.php?t=281706
Old Jul 26, 2004 | 09:25 AM
Thanks , one step ahead of you
Hurin
Dec 13, 2014 07:38 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
Jul 4, 2005 05:00 PM
