Tierod question threads/degree
Old May 22, 2003 | 01:30 PM
Eddie95Z28's Avatar
Ok I recently changed one of my tierod ends and I guess the new one was a bit longer because my tire is now a few degrees out. I figure I can pop the tierod end out twist it into the rack a spin or 2 and get it back in alignment. I know I need a pro alignment done but I don't have the time as I am leaving for vacation soon. and I want to change the other tie rod end for good measure then get the alignment professionally done. So bottome line question is:
How much will the tire toe in per spin of the tie rod into the rack?
Old May 22, 2003 | 04:15 PM
Eddie95Z28's Avatar
This board moves too fast sometimes... I will TTT this once... then let it die a graceful death.
Old May 22, 2003 | 04:36 PM
I don't know the relation of turns to degrees.
You only have to loosen the lock nut and turn the inner tie rod on the wrench flats to make the adjustment. No need to remove the joint from the knuckle.
Old May 22, 2003 | 04:42 PM
Eddie95Z28's Avatar
So the tie rod itself would spin... Is the tie rod end or rack counter threaded? I didn't notice that the tie-rod had flat spots for that. I assume I would have noticed when I got there though. Thanks.
EDIT: Any pictures?.... just kidding.
Old May 22, 2003 | 04:45 PM
Trust me. I have done it. It works.
Old May 22, 2003 | 04:51 PM
Eddie95Z28's Avatar
I trust ya' Save me a few seconds clockwise or counter-clockwise to bring the tire in ?
Old May 22, 2003 | 04:56 PM
I don't really remember. Shorten the length to move the toe in.
I do have a pic somewhere, but can't find it.
[edit] Found a pic . You can see the flats in the foreground-a little blurry.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
