ticking under load
Old Jun 3, 2009 | 01:35 PM
namctx's Avatar
ticking under load
There is a slight ticking when the car is under load. More noticeable in lower RPMs (especially when tq converter is locked up) If I put in neutral and rev there is no ticking, throughout all RPMs. What do you guys think the problem could be?
Car is a a 94 formula. Only big mods are LE2 heads, CC306 with Comp "R" lifters... I'm pretty sure the lifters are before the bad batch though.
Old Jun 3, 2009 | 02:41 PM
Venomous360's Avatar
sure its not spark Knock??
Old Jun 3, 2009 | 02:55 PM
CheshireCat's Avatar
When it comes to "ticking" I start looking for exhaust leaks. A loose manifold or header bolt can cause a tick. Also, a tick that is much more noticable under load.
Old Jun 3, 2009 | 04:33 PM
namctx's Avatar
Thats what my buddy said he thought it was too (exhaust leak). I think i'll end up replacing the header gaskets and do a tune up to see what happens. Thanks both of you for the input!
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
form94
Sep 23, 2015 07:30 AM
1slow93z28
Sep 1, 2015 06:22 PM
karpetcm
Aug 14, 2015 03:02 PM
