Ticking noises from my engine
Old Jul 12, 2004 | 05:01 AM
ironthumb's Avatar
Hey-guys and gals,
I have a 96 Z28 camaro and all of a sudden I have been hearing this ticking noise that is coming from the engine. When I go from 1st to 2nd gear I hear the noise as I increase the RPM's to get into the next gear. As I upshift to 4th and 5th the noise get louder and faster but if I keep my speed steady I no longer hear the noise. Someone told me that it could be a valve tick which I know nothing about. Does anyone have any idea what this could be?
A little history on the car. I have had the for the last 8 years, I bought it new in 96. In 02 I blew the engine out because I neglected changing the rediator after i discovered a small hole in it which lead to me blowing the heads of the engine. Since having the engine rebuilt, I rearly ever drive the car. I only start it up once a month and maybe drive on nice hot california days with the top off. I just recently notice this noise when taken it for a spin around the corner.
Any information you give would be greatly appreciated!
Ironthumb.
Old Jul 12, 2004 | 06:20 AM
newWolforder's Avatar
Sounds like you may have an exhaust leak..if you just did the heads then you must have had the exhaust manifolds off check for leaks there....also could be a sticky lifter or not properly tightend rocker also caused by having the heads off.
Old Jul 12, 2004 | 06:34 AM
icebergslim2718's Avatar
C4
Fatdog2
Feb 12, 2015 12:24 PM
importkiller94
Jan 17, 2015 09:03 PM
squarehead
Nov 21, 2014 08:02 PM
Omega9
Aug 2, 2002 12:33 AM
Zone
Jul 29, 2002 07:43 PM
