ticking noise and miss
Old Apr 10, 2015 | 08:09 PM
94Z28LS1toLT1's Avatar
Hey guys here's my issues I have a ticking sound coming from the driver side valve cover it comes when I'm coming to a stop,it will tick for less than a minute then go away and comes back occasionally.
2nd issue is only when I'm on the freeway when I'm around 65 to 75 mph (3k rpm)and keep my foot on the gas like I wanna go faster the car will hiccup/jerk I seen the rpm like kick back. When I go 0 to 50 no freeway mph the car accelerates perfect and powerful.
1.Car fires up fast and stays on idling perfect.
2. Spark plugs, wires,distributed cap and rotor done,fuel filter,ignition module all been changed,I do what could cause this thank you guys
Old Apr 10, 2015 | 10:28 PM
Re: ticking noise and miss
What does the oil pressure look like as you are coming to a stop? Does the tick get worse on harder stops?
Old Apr 11, 2015 | 09:15 AM
The oil pressure is below 20 coming to the stop and the ticking is worse on harder stops yes
Old Apr 11, 2015 | 09:46 AM
It's like 18 to 19 psi Fred
Old Apr 11, 2015 | 10:09 AM
Just checking to see if it was dropping to "0" which would indicate the oil pump pickup has come loose. Does not appear to be the case. Oil pressure is proportional to RPM.... as RPM drops, pressure drops.
Use a stethoscope to lo locate the specific source of the noise. If it's a valve train component, check the valve adjustment.
You second problem, the stumble when to want to accelerate, will probably take a PCM data log to track down. For now, check for a torn rubber inlet elbow, or the elbow not being fully on the throttle body, particularly at the bottom.
Old Apr 11, 2015 | 06:17 PM
Woo that's good that oil pressure is fine the ticking is coming from the 2 first rocker arms that's closest to throttle.Now how do I adjust the rocker arms without messing them up?and to see if there is play or if they are too loose.Thank you
Old Apr 11, 2015 | 08:35 PM
Hey Fred the red wire behind the alternator that the nut holds,the wire needed a different terminal B.C. between the wire and terminal were pretty loose. I remember when i bought the car the voltage gauge never moved,and after the car gets warm, the gauge moved up and down a lot
Old Apr 11, 2015 | 10:46 PM
https://plus.google.com/photos/109166711352110492281/albums/6136682654127542865?authkey=CMaEy42zhL_V7AE
Old Apr 12, 2015 | 08:35 AM
I don't get any audio on the video, or were you just showing that the rockers are loose?
Use Shoebox's valve adjustment procedure:
4th Gen LT1 F-body Tech Articles
Old Apr 12, 2015 | 12:57 PM
I'm having issues trying to post the video
Old Apr 14, 2015 | 07:19 PM
yes just showing the rockers being loose just found out my lifters are bad on cylinder 1,but do I need to take the intake manifold off and go through the trouble to change the lifters or can I switch oils and motor flush it to get any sludge I think this didn't happen till I used Castrol edge10 30 fully senthentic
Old Apr 24, 2015 | 08:27 PM
Any suggestions please
Old Apr 29, 2015 | 06:21 PM
Just changed oil to 5w 30 valvoline now ticking is gone......so is valvoline better then Castrol edge fully synthetic 1030.hella confused about the ticking problem I had.
Old Apr 30, 2015 | 05:19 PM
blac94Z's Avatar
Lifter is bad in cyl 1
KYWes
Jun 14, 2022 06:52 AM
colts0455
13
Aug 7, 2015 09:15 PM
techstar
Aug 6, 2015 11:20 AM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
