Ticking coming from water pump Help
Old Nov 23, 2004 | 08:47 PM
Zjoker's Avatar
Question Ticking coming from water pump Help
Has anybody ever had this problem. At first I thougth I bent a push rod or had a loose spark plug but no there is a ticking sound coming from the water pump or at lease the front of the engine. Please help
Old Nov 23, 2004 | 10:30 PM
dmoor88's Avatar
Re: Ticking coming from water pump Help
sounds like its starting to go. the ball bearings on the shaft exiting the waterpump can cause the shaft itself to vibrate and loosen up, causing a bad leak.
HectorM52
Jul 30, 2017 11:46 AM
MattFick
Feb 15, 2015 10:16 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
