Ticking.....After header/rr install
Old May 31, 2008 | 09:30 PM
Jazsun's Avatar
Got the car fired up today, it idles great. After about 5 minutes or so it starts to develope a tick on the passengers side. You can hear it best from under the car but up top its hard to tell where its coming from. The 1.6rr's were put at 1/2 preload so I hardly believe they are making the noise.
Is it typicall that a header leak would not be heard until the car warms up? It seems it was worse after I drove it a couple blocks and then came back. I will try tightening them down some more. Currently I am using felpro header gaskets.
Old May 31, 2008 | 09:39 PM
mrmint69's Avatar
Mine had a leak and after it warmed up the sound would slowly go away until it was almost unheard. I tightened my header bolts once a week until they they all were perfect. It took 3 times to get this to happen. If you think the RR's are to blame pull the valve cover and see what happens when the noise starts. I think the noise goes away after they warm up because the heat swells them a little to seal the leak. I would not think RR's sice the sound is best heard from below.
Old May 31, 2008 | 10:12 PM
Green96Z's Avatar
Sounds like a classic exhaust leak. Just keep tightening those header bolts and eventually they will seat. The tick could also be coming from your y-pipe, which is where mine is right now .
Old May 31, 2008 | 10:16 PM
pizzi-man's Avatar
a lot of people mistake a exhaust leak for a lifter or rocker. an exhaust leak at the head will be a tick and further down the exhaust it will be more of a rumble
Old May 31, 2008 | 11:25 PM
MeanGreen97Z's Avatar
I'm thinking you need to check the rockers.
Old Jun 1, 2008 | 12:06 PM
Jazsun's Avatar
Check the rockers as in, re lash them all? Is it possible a plug to be arching? They are brand new wires so I can't really see it happening.
Old Jun 1, 2008 | 12:18 PM
LT1Camarogirl's Avatar
Question
thats what i thought too...turns out one of the wires was arching on the water pump...go figure
Old Jun 1, 2008 | 01:34 PM
Jazsun's Avatar
See, I dont understand how plug wires arch when they are insulated? How the hell does this happen?
Old Jun 1, 2008 | 11:15 PM
Jazsun's Avatar
Well I drove it around and got it up on ramps while running. Still couldnt pin point it. It seems loudest under the car by the passenger header and oil pan. Using a long screw driver I listened to the valve cover in 4 diff areas, and the primaries...nothing really. The only thing which resembled the noise close was the injectors.
I confirmed it's not plug wires since I looked in the dark. If I pull injector wiring harness while its running for a few seconds would it be real bad on the engine?
All the header bolts on the that side are just a tight as they were orignally, haven't loosened up or anything but I still made sure they were all pretty dang tight.
Old Jun 2, 2008 | 03:54 AM
1redTA's Avatar
re
check the heat shields as mine were rattling also.
Old Jun 2, 2008 | 12:07 PM
Kevin Blown 95 TA's Avatar
I had a really hard to find tick on my car last summer and it turned out that one of the header tubes was leaking slightly at the flange where the weld was - I pulled the header and repaired the inside of the tube and that fixed it. It almost drove me nuts trying to find it though.
Old Jun 2, 2008 | 07:23 PM
Jazsun's Avatar
Thanks for the replies, the thing is...It only starts after the car gets warmed up. And if its warmed up and then I turn it off....then wait a few minutes and turn it back on it won't start agan for 10 seconds or so. I bought a stethoscope and If I put it on the last primary its a little louder there, on the valvecover its even a little louder. So I am suspecting its a rocker in that back corner. The thing that gets me is why is it louder under the car if it indeed is a rocker? Would that echo through the exhaust or something? Does that make any sense?
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
