True Double Roller timing chain and gears
Old Apr 20, 2005 | 12:10 PM
weinerschizel's Avatar
Question True Double Roller timing chain and gears
Does anybody know of a good deal on one of these setups. Mine would be a bit unique. I'm looking for one that doesn't have to have the water pump sproket on the cam gear as I'm getting an electric water pump. Also, it has the have the fitting for the opti dowel pin as I have a 1994 setup.
Thanks much!!!
Old Apr 20, 2005 | 12:13 PM
Pasky's Avatar
Re: True Double Roller timing chain and gears
Get a cloyes double roller for $80.
Contrary to what people have said, I didn't have to grind the timing cover....mine is a 95.
Old Apr 20, 2005 | 12:24 PM
sssalah's Avatar
Thanks much!!!
Wont work, you must go wth vented type opti.
Old Apr 20, 2005 | 12:40 PM
1-bad-z28's Avatar
yep..you need a 95 and up opti to get it to work
Old Apr 21, 2005 | 09:12 AM
Yeah .... I actually found summit brand true double roller timing chains that would work on a 95+ setup for 40$ However, I have a 94 with that STUPID dowel pin so it costs me $350 for one
Anybody got any great ideas? I could perhaps redo the whole ignition again with a 95+ setup.... but then I need a different cam as well right???
Old Apr 21, 2005 | 11:38 AM
RicocheT's Avatar
Im in your same position! Sucks to be us haha.. You don't need a different cam no, just a longer dowl pin.
Old Apr 21, 2005 | 11:56 AM
where could a person get a longer dowell pin??
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
97 RedSS
Jun 10, 2003 07:58 PM
