Thrust issue
Old May 20, 2011 | 06:15 PM
Nickw059's Avatar
Angry Thrust issue
1994 camaro z28, yesterday I punched the throttle the something under the car popped and was very loud and sounded like it hit the under cariage. If you grandpa it it drives really good, but if you get on it hard it countinues too make that god awful noise. I thought at first I broke a U-joint, but obviously not since i'm still driving it. jack it up, checked everything quickly but didn't notice anything. transmission mount, drive line, and pinoin all seems good. I'm going too pull it over a pit tomarrow and do a better check. any ideas??? It scared the **** outta me!! something isn't holding up under a load.....
Old May 20, 2011 | 06:45 PM
Kevin Blown 95 TA's Avatar
Re: Thrust issue
Really sounds like a transmission mount. I know you checked that, but it's the first thing that came to mind.
Old May 20, 2011 | 06:56 PM
Nickw059's Avatar
Re: Thrust issue
Thats what I was thinking but i'm going too do a better chekc tomarrow! thats what I hope it is!
adam85's Avatar
Re: Thrust issue
Did you pry up under the tranny mount on to the cross member? I have had them break and just wear out and flex a lot on mine and still thump.
Old May 20, 2011 | 07:03 PM
SkiBumDreams's Avatar
Re: Thrust issue
mine did a similar thing and it happened to be the torque arm came unbolted from its front mount. was hard to see on my first quick inspection.
Old May 20, 2011 | 08:14 PM
Nickw059's Avatar
Re: Thrust issue
well I took it into my shop over the pit, got under and yes! transmission mount is destroyed! alot easier to change than the ones I usually change on semis haha
Old May 20, 2011 | 08:33 PM
adam85's Avatar
Re: Thrust issue
It's nice to have a easy fix once in a while! Good job man.
TheGreenZ28
Oct 4, 2020 11:29 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Fastbird93
Jun 3, 2015 05:56 AM
