Thrust Bearing Play?
Old May 11, 2008 | 09:22 PM
GreasyB's Avatar
How much play are you allowed for the thrust bearing. I am was in the process of pulling my crank hub off. And noticed I could move my crank.... I am pretty sure my thrust bearing is shot. What do you guys think about this.
Old May 12, 2008 | 06:55 AM
End play limit specs are .001"-.007".
Old May 12, 2008 | 07:15 AM
cnorton's Avatar
I usually don't settle for anything less than .004" thrust clearance during assembly.
Old May 12, 2008 | 07:47 AM
96capricemgr's Avatar
Eagle crank by chance?? They had a batch go out with bad machining on the thrust surface.
Old May 12, 2008 | 08:57 PM
GreasyB's Avatar
No, stock crank. And I got way excessive clearance on that then. I am not totaly sure how it happend. But yet I still got great oil pressure.
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
95craz28
11
Sep 12, 2015 07:47 AM
Bxlt1
Sep 10, 2015 08:16 AM
